Ricoh MPC2800/2500 keep prompt to close side door
  • brianho80
    • Sep 2009
    • 198
    Hi guys,
    i come across a problem that MPC 2800 keep alert to close the side door even it has been closed and machine keep operate and stop until i open and close side door for several time and on/off machine.
    i'm actually suspect the switch i took in the picture.. anyone has this problem before?
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: Ricoh MPC2800/2500 keep prompt to close side door
    Cheat both door switches, if it still alerts for the door then you have either a faulty switch or a firmware update needed. If it works check the corresponding activators on the door, the plastic covers could be snapped off.
      • 37637
      That is the door switch for the side door. Those push button switches have been known to become faulty, especially in an environment where there is a high level of vapor or very small particles in the air which can get in the switch and contaminate the contacts. Also as ruben says, it could be the plastic flange that actuates the switch.
      • brianho80
        • Sep 2009
        • 198
        thanks ruben & slimslob, will try that out again..
        anyway, firmware will caused this problem?
          • 37637
          There was an engine update for the MP C2800/3300 to correct a false detection of cover open on the bridge unit. It extended the time necessary to detect cover open to compensate for momentary loss of contact due to vibration.
          • NORA
            Hi , my machine indicate the bypass door( door used for printing envelope ) need to be closed. the fact is the tray already been closed. but machine keep prompting the signal and unable to print please help..
            • brianho80
              • Sep 2009
              • 198
              Hi Nora..
              for my case, i replace the door switch, it solved my problem.
              you may consider as 1 one your troubleshoot options.
              • Polarbear
                • Feb 2012
                • 1070
                in sp mode you can also do input check on most of the switches to find the faulty one.
                Press the GREEN button!!
