MPC2800 scan memory ?
  • GeorgeBest
    • Jul 2009
    • 520
    HI,
    Customer called saying that he could not make a scan !
    When he tries the display gives an error saying that there is unsufficient memory for using the scanner . .
    Is there an option for clearing the (scan) memory on this one ?
    Thanks in advance
    Gr
  • redneckstylin
    • Sep 2011
    • 173
    Re: MPC2800 scan memory ?
    make sure your compression is max out and divide and send is off aswell I default all my junk to 300 dpi and text line multipage pdf
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Are you scanning to email? If so, disable the max file size and split settings in User Tools. Also, make sure their IT have a reasonable max file size limit on the server either increased or disabled for the copier; the scan files can get really large really easily.
