ADF issue - MP C3003 - We're stumped for the moment.
  • Richariri
    • Dec 2013
    • 163
    [Jamming] ADF issue - MP C3003 - We're stumped for the moment.
    Hello all,
    I have an engineer on site at this very moment with a real brain tickler and I wondered if any of you have come across this issue.
    We have had the MP C3003 installed on site for at least 6 months now and this is it's 1st issue.
    It has a very intermittent Jam at number 17 (paper did not reach output sensor) and our engineer is unable to find anything foreign stopping the transport and as it's so intermittent I wonder if something is moving about or out of alignment causing the paper to slow and mess up the timing.
    Has anyone had any similar ADF issues on the '03' range? Any input will be a help.
    Thank You
    • 37491
    Re: ADF issue - MP C3003 - We're stumped for the moment.
    My guess would be a dirty original exit sensor, especially if in a high dust environment.
    • Eric1968
      • 2458
      Check the holder for the optional stamp unit (for the fax unit). It is located under the document table. You can pull the holder out to place the stamp. If it's not positioned correctly you get original jams. Don't ask me why, but I saw it during training.
      • TonerMunkeh
        Professional Moron
        • 3865
        Is it an ARDF or a single pass? There's an RTB out for a jamming issue on the single pass feeders.
        Hit it.
        • turbojetboy
          • Aug 2009
          • 279
          image.jpgHave a look at this. There is also a recent bulletin showing a mod and new part number, for another problem area in this feeder.
          • Richariri
            • Dec 2013
            • 163
            Our tech says...
            The doc feeder is not Single pass. It has had all the sensors and tyres cleaned.
            The Fax stamp cover is 'clicked' into place and shouldn't cause the issue.
            We have tried and checked everything Ricoh knowledgbase suggests (which isn't much)
            Any other ideas?
            • Imprestik
              • Aug 2012
              • 297
              Under the document feeder you have a white sheet with velcro stuck to it, remove it and you will find a sensor on a slider (kind of like in the paper trays) which obviously slides forward and back
              make sure this sensor on the slider is actually set in the rails themselves, otherwise you will find the sensor on a slight angle and it will come out of position by just opening and closing the document feeder causing this issue
              • ruben
                The New Guy
                • Oct 2012
                • 1203
                If the customer isn't using the stamp function then you should tape the stamp unit closed. There is a known fault with these units, causes Jam 001 error codes mostly. Just moving the unit back to its home position is not good enough.
                • Athlontini
                  • Jun 2012
                  • 269
                  Is this happening only with a certain paper size, or certain originals?
                  • Richariri
                    • Dec 2013
                    • 163
                    It has happened only on A4, and it is so intermittent we are starting to think it's the user's originals being dog eared etc.
                    I think for now we're just going to monitor the situation as they haven't had a jam (touch wood) since I logged this thread.
                    Thanks for all the help guys, I don't know where I'd be without this forum.
                    • ewizzy
                      Dirty toner monkey
                      • Feb 2014
                      • 55
                      In a metal asylum
                      • Athlontini
                        • Jun 2012
                        • 269
                        If the issue comes back, I'd try replacing the whole feed assembly. Had one of these that would jam only on a customer's specific original (which was not dog eared or anything) but ran everything else fine. Took their originals to one of our showroom 3003's and they ran fine. Swapped out the feed assembly and they've been good.
                        • Mr.Claire
                          • Mar 2008
                          • 49
                          We have had 3 so far with this problem. Changed the sensor to the old one and it works fine. One unit was right out of the box. C3003's seem to have faulty DF sensors.
                          • Marvin Rivas
                            Originally posted by Marvin Rivas
                            This problema is for the ADF original stamp case, this must be to the rigth, in other position cause paper jams.
                            • Marvin Rivas
                              This problema is for the ADF original stamp case, this must be to the left
                              Sorry for the wrong information, the stamp base must be to the left totally.
