Ricoh SP-4210
  • hptech
    • Jul 2011
    • 5
    [Jamming] Ricoh SP-4210
    I have two Ricoh SP4210 giving me the same problem. They are both jamming from the cassette. It's hit or miss when it will do it. sometimes it jams on the first page or two or will printer 20 pages before it jams. They are paper late jams and the paper isn't hitting on anything or getting stuck in the printer. The MP tray work fine without any problems. I have changed out the pickup rollers and sep. pad, cassette, and sensors. Anybody have any recommendations?
    • 37490
    Re: Ricoh SP-4210
    Print the logging data and check what the jam location number is. This will tell where it is actually jamming.
    • hptech
      • Jul 2011
      • 5
      Re: Ricoh SP-4210
      I tried to print the logging data on both machines but after it would press enter when it said execute it would go back to the logging data screen. I was able to print it on other machines they have with no problem. Any Suggestions?
      • CanadianKiwi
        • Nov 2012
        • 12
        Re: Ricoh SP-4210
        The sensor under the black plate on the bottom of the machine on the right is probably out of place.
        • hptech
          • Jul 2011
          • 5
          Re: Ricoh SP-4210
          I have replaced the both of the sensor flags on both sides of the pickup roller. Do you think the actual sensor went bad?
          • hptech
            • Jul 2011
            • 5
            Re: Ricoh SP-4210
            OK I was finally able to get the logging data to print on one of the machines.
            The Jam location number is
            Total jam is 89
            -20 has 74
            -24 has 12
            power on had 2
            Any suggestions?
              • 37490
              Re: Ricoh SP-4210
              Total jam is 89
              -20 has 74
              -24 has 12
              power on had 2
              Any suggestions?
              look at the SMC log data and Jam Location SP 7504, which is where you got those numbers from, should also say where each of those jam numbers refer to, such as J003 is a tray feed jam. Otherwise, look them up in the Service Manual.
