672 codes on mp 6001 and mp 7500
  • fshead
    • 2376
    so i have two ricohs i need to place in the field and my mp 6001 is giving me a 672 code,after reseating the controller and memory dimms i pull the sd card panel and out and reseat all.
    machine comes to ready but when i put all covers on and reboot,same ole 672 code..
    turns out the cover for the sd card had a screw a little longer than needed and this caused the 672 code to come up..must be grounding the controller out..
    on my 2nd machine i have a mp 7500 with a shattered control panel.
    replace the 672 code comes up.
    now this machine is missing the print,scan card but has the 2 memory dimms on it.
    it should work without the print scan option,right?
    what must i have that i could be missing.
    i bought it like this and decided to try to bring it back as it only has 350k on it
    thnx
    • 37556
    Re: 672 codes on mp 6001 and mp 7500
    For the MP 7500, If it has the printer and scanner buttons, then someone removed the Print/Scan SD card. Otherwise, it has the optional memory unit installed to expand total memory to 512MB. Either way, it should still function as a copier.
    • drwevil
      • Nov 2013
      • 54
      Just had a look in the service manual and there is an RTB about System/Copy firmware...
      I seem to remember this when I was servicing a bunch of them...
      Hope that helps
      • maydaycopiers
        • Aug 2013
        • 3
        Check the HDD, see if you can fire it up without the HDD attatched.
        • fshead
          • 2376
          thats what i thought too,dont want to buy the print,scan sd card till i know i got this working..on a firmware update cant say it will even boot to do
          the update..thnx
          • fshead
            • 2376
            I tried pulling the drive and booting but same 672.do you have to disable the drive in service mode first?
            cant get in2 service mode at all
            i did double check the memory sticks on top of controller and none..
            do i need at least one stick.
            looks like laptop memory i have laying somewhere..
              • 37556
              Yes it does need to have at least one memory stick in it. It uses 256MB sticks but you will have to check the service manual to get the speed.
              • fshead
                • 2376
                ok thnx
                .just trying to rule out a smoked controller which would make this a pars only machine...
                • johnyb
                  • Feb 2011
                  • 167
                  672 can also be the psu that sits in the controller unit...
                  The fuse blows, shatters! New psu if this is the case!
                  • fshead
                    • 2376
                    thnx
                    found memory and added a 256meg on top slot,still 672 ,will ck power supply..
                    does HYTEC do ricoh controller boards?
                    i use to use them years back with sharp and minolta boards,,
                    i remember MIDWEST was a repair option too..
                      • 37556
                      thnx
                      Was that adding a second 256MB or is it the only one? If it is the only one, try it in the other slot. If it is the second 256MB, remove the original and replacing it with the new one. I know that bad memory will throw a code, but I am not sure if only one has to be in a specific slot.
                      • fshead
                        • 2376
                        thnx
                        i put a 128meg on the bottom slot,
                        256m on the top..cleaned the memory wth alcohol before mounting it.
                        i just dumped a bunch of old machines so now i can
                        open everything up and see where i am at..
                        hate to make this a parts machine only but i wont buy a controller if thats it..
