How can I reset the Web Image Monitor?
  • Jeremy-Ricoh
    • Oct 2007
    • 24
    Hello All,
    I have a Ricoh Aficio SP C420DN, it's a rather new device to the market, and new to me. During my testing of the web image monitor I seem to have set something incorrectly, and now I can't reach it over the network.
    When using Static IP address or DHCP the device is un-ping-able from my computer.
    This all started happening after I set some things in the Web Image monitor. Unfortunately, I don't remember what I did (it's been a few days).
    Is there anyway to reset everything in the WIM without actually logging in to the WIM?
    I tried deleting the user codes, but it looks like that only resets the items set on the front panel of the device.
    USB works fine.
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    What settings are shown on the configuration page that you print out? Settings such as ip addy, etc.
    Maybe you somehow disabled the tcp/ip protocol; the config. page will tell you that.
    You should be able to config. the printer through the control panel-as much as that can sometimes suck.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • Jeremy-Ricoh
      • Oct 2007
      • 24
      Right now it's on the DHCP, using the corp network.
      On the Config page it says
      IP address : 172.27.183.183
      Gateway : 172.27.183.129
      Subnet : 255.255.225.128
      Host Name : RNPCF2AEF
      If I ping 172.27.183.183 it returns "Request timed out"
      If I ping rnpcf2aef it returns "157.55.143.176" "Request timed out".
      When on a private network (using 10.0.0.4 printer, and 10.0.0.8 computer) it does the same thing "Request timed out".
      • Jeremy-Ricoh
        • Oct 2007
        • 24
        Oh friggen heck..
        So I thought to my self, maybe IPSec is on?
        It was, so I disabled it, and now all is happy.
        Do you think it could be a problem with the firmware not liking IPsec?
        • schooltech
          • Jun 2008
          • 504
          IPSec is a layer 3 protocol, having to do with VPN's. Even though you have a 172.27.x.x. addy, that still is a private-range addy. 172.16-172.31 is a class b address used for non-routable addressing. So, technically, you are still on a private network. Anything in 10.x.x.x is because it is in a class A range.
          It must have been looking to be involved in tunneling encrypted packets to a non-VPN setup. Not exactly sure there, but it obviously did not like it.
          That's an oddball subnet for a Class B network, but it will work-it's just reducing the nodes on 'that' particular network.
          Brings back networking memories of college courses & an old IT job I had. Man, how much you quickly forget if not in it on a daily basis.
