MPC 3500 toner problem
  • Butrus
    • Jan 2012
    • 115
    Machine displays ADD TONER
    There is toner in the bottle
    I put another toner botle in and it WONT EVEN START LOADING TONER...nothing happens
    I also put in another drum/dev unit..the same...wont even try to load the toner
    I vacumed the tubes,put apart the toner pump,cleaned it(it turns nicely)
    The machine always displays add toner and whatever I do it wont even try to add toner.
    If I try forced toner supply it fails immediately
    Would changing the pump resove this?
    (altho only electrical part in there is magnetic clutch.How would machine know it has to try adding toner by replacing it)
    If I try output check,toner suply pump Bk,I can hear the clutch engaging.
    Thanx
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC 3500 toner problem
    The pumps on these machines are rubbish, they always break. If you are using non-OEM toner they will break a lot quicker.
    • Debs1964
      • Oct 2010
      • 1693
      Close the lower right door
      There are 10 types of people in this world, those who understand binary maths and those who don't
      • neergish
        • 177
        Common issue, New toner pump should fix it, I've done lots of these. Something about something being worn in the pump itself I seem to remember seeing a diagram of it somewhere cant for the life find it.
        I have had to change the toner supple nozzle on one machine as well but this was a once off.
        "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
        • Butrus
          • Jan 2012
          • 115
          Thanx man!
          (well you know what I mean)
          Its loadning it now but doesnt do it.
          At least it makes sense now.
          • Debs1964
            • Oct 2010
            • 1693
            Originally posted by Butrus
            Thanx man!
            I just checked, nope, definitely not a man
            Glad I could help, that one really gets you going first time you come across it
            • Butrus
              • Jan 2012
              • 115
              Ha he ha
              Why machine wont go to ready even if I put toner directly(manually) to the dev/drum unit?
                • 37556
                I've been there. Some machines don't display door open while the add toner message is being displayed. I've learned over the years to check tha all doors are closed completely.
                • Eric1968
                  • 2458
                  Ha he ha
                  Just replace the toner pump. Common problem on these machines. Manually pouring toner in the DV-Unit doesn't solve it. It can lead to overtoning and dirty hands.
                  • imaginemoko
                    unTrusted Tech
                    • Jan 2008
                    • 289
                    Sir are you using the original toner? or the OEM(orange is better than green its headache). can we try to install a toner from a working machine if it will respond and load the toner. if not then install a new pump. best of Luck Sir.
                    fix the customer first then fix the machine... its simple and makes life more easy.
