MP2500 press start key to continue when copying from glass
  • Elmo
    • Feb 2010
    • 541
    Hi All
    Im looking at an mp2500 when copying from the glass if you ask for more than one copy it produces the 1st page
    then stops and asks you to press the print button for next original or to continue
    can this be turned off i cant remember or find where the setting is
    thanks
    I Used To Live To Fix Things Now i Fix Things To Live
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP2500 press start key to continue when copying from glass
    User Tools > Scanner Features > Scan Settings > Wait Time For Orig.: Exposure Glass > Off.
    • Elmo
      • Feb 2010
      • 541
      Thanks for the reply forgot to mention this is a basic machine no print/scan
        • 37491
        Just press the # key when it says "Insert next original or press #". This tells the machine that you do not have additional originals.
        • Elmo
          • Feb 2010
          • 541
          Yep i got that bit
          i was just wondering if there was anyway to turn it off
          so if u set it to do say 10 copies and press start it does all 10 without asking you to press the # or start key
          • rthonpm
            • Aug 2007
            • 2854
            The issue is that the machine is trying to automatically collate. If you turn the feature off, if someone comes along with a set of originals that they put into the doc feeder and want twenty copies, they'll get twenty copies of the first page, twenty copies of the second, and so on. Just hitting the # key after scanning your one page is going to be the better option.
            • Elmo
              • Feb 2010
              • 541
              The machine is in a customers warehouse they are a simple bunch they like to lift the lid put the original
              on the glass and get 5 copies
              for this customer it would be easier to have it turned off
              they rarley have more than one original but require several copies of it
              problem is they previously had a 2018d that didnt have this feature/problem
              • Elmo
                • Feb 2010
                • 541
                Got it user tools---copier features---auto sort ---- off
                thanks rthonpm u pointed me in the right direction
                • rthonpm
                  • Aug 2007
                  • 2854
                  Glad I could help. I've had a lot of experience where 'older' users would just use the glass instead of the ADF for multiple copies. Turning off the auto sort originally seemed like a good idea until the first time I had someone doing multiple copies of a deposition or a training manual and having them raise all holy hell when the machine wouldn't collate their fifty page document that they needed twenty or thirty copies of.
                  The warehouse guys are usually quite a simple lot like you said. I'm guessing it's mainly multiples of packing sheets or similar items, in which case the originals are probably so trashed they'd never survive the doc feeder, or they're just cut out of a cardboard box.
