MP C2051 / color copy fuzzy
  • CSI
    • Oct 2008
    • 73
    [CQ] MP C2051 / color copy fuzzy
    hi,
    Sorry, i'm using Google translate ...
    On a MP C2051 I have a shift of color synchronisation
    Sheet sort in the sense X, the decalage of color is in the sense Y.
    The decallage is more prononce in yellow on 0.5 millimeter.
    Cyan 0.3 millimeter
    Magenta 0.2 millimeter
    So the color copy is fuzzy
    I have been replaced:
    The 3 color drums
    The ITB complet
    cells DI
    Laser Entier (with the entire procedure that goes well)
    Setting MUSIC 2111 a b c ...
    Firmware are ok
    The problem still persists !!!
    Total color count : 62577 pages
    Total black count : 39850 pages
    Have you a idea ?
  • Jaxom
    Lead Technician
    • Apr 2011
    • 62
    Re: MP C2051 / color copy fuzzy
    Did you do C first then A? C is rough alignment and A is fine alignment.
    That is all I can think of. The only part left is the laser unit.
    Have you tried turning it off and on again?
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Make sure that the laser and drums are properly screwed in place. Clean the optics and re-run Line Adjustment C then A; twice.
      • Eric1968
        • 2458
        First thing to do is check the Line Positioning Adjustment result (SP2-194-010-012), and check the counter measure list in the Service Manual. Color Shift can happen in Main Scan (Laser Unit) and Sub Scan direction (Drums). If you know in which direction the shift occurs, then you'll know what to replace or adjust. If the density of the patterns is not enough, the DV-Units can also be a suspect.
        Another solution can be to reset process control data to default for Copy SP (SP5-610) and Printer SP (SP1-011-001). Then run Process Control and Line Adjustment C and A (Run A twice, like Ruben said).
        • CSI
          • Oct 2008
          • 73
          I will check SP2-194-010-012
          Ok for C then A twice. I do tomorow.
            • 37489
            Before doing anything, clean the image density sensor assembly. I have had color registration pull back into alignment just by cleaning the sensor.
            • CSI
              • Oct 2008
              • 73
              The image density sensor assembly is new
                • 37489
                If I remember correctly, there is something at the front of the machine that tilts the ID sensor assembly into and out of position. If there is anything binding the movement of the ID sensor mount plate, it could cause incorrect positioning of the ID sensor.
                • Iowatech
                  Not a service manager
                  • 3930
                  Hopefully you can find the "birth certificate" for that machine, the paper that comes with new machines from Ricoh that shows all of the adjustments from the factory. If you can find that, I'd recommend you check that the adjustments listed there are correct first before you try any other new adjustments.
                  (It sounds a little bit like somebody did a memory reset to the machine when one was not needed. I'm probably wrong, though.)
                  • CSI
                    • Oct 2008
                    • 73
                    SP2-194-010-012 report 1
                    I'll change dev unit color
                    • CSI
                      • Oct 2008
                      • 73
                      After struggling a few hours on this damn engine I managed to be correct copies by changing the factory came with my new laser values​​!
                      Info Data 20140801114141400.pdf
                      • zeeaxis
                        Manager TSD
                        • Nov 2008
                        • 28
                        Haha..... Birth Certificate....
                          yes that's what Ricoh calls the SMode settings sheet for the machine.. it used to be stored under an inner cover on the front side of the machine..
                          it IS actually called the " Birth Certificate "
                            • 37489
                            Info Data [ATTACH]25866[/ATTACH]
                            In other words you actually followed the service manual directions for replacing the laser diode unit. That must have been a radical concept for you.
