RICOH MP 2851
  • copierlady
    • 338
    RICOH MP 2851
    Setting up a Richo MP 2851. I am locked out of certain functions. I can not change the ip address, "log in" or change several other functions. It tells me I am not authorized. I work mainly on Konica Minolta. Is there a master password on these machines?
  • rgcs1
    Systems Intergrator
    • 69
    Re: RICOH MP 2851
    "admin" and blank password, if that dont work then
    Log in with Supervisor and leave the password blank.
      • 37544
      Re: RICOH MP 2851
      Supervisor can do one thing. Change the admin login credentials.
      • CrapAimer
        • 296
        Re: RICOH MP 2851
        go in through web page monitor, user name admin no password and switch off the authentication
        • copierlady
          • 338
          Re: RICOH MP 2851
          Thanks guys. I'll let you know how it goes.
          • halbrandenburg
            Bypass Tray Expert
            • Sep 2011
            • 92
            Re: RICOH MP 2851
            What you describe here could be quite different depending if you are going through the Web Image Monitor or accessing settings through the USER TOOLS standing at the MFP, which does not require a log in by default like the Web Image Monitor does. If you are getting restricted prompts at the MFP "it tells me I am not authorized". This sounds like you are going through the USER TOOLS, and indicates someone has protected some of the administrator settings.
