MPC4502 SC 687
  • OEDS
    • Aug 2025
    [Error Code] MPC4502 SC 687
    Hello Everyone,
    Have a MP C4502 at a customers site which stalls during a copy/print job and throws a 687. Per the service manual:
    Memory address command error - The BCU does not receive a memory address command from the controller 120 seconds after paper is in the position for registration.
    Loose Connection
    Defective Controller
    Defective BCU
    Steps taken to correct problem:
    • Updated all fw including engine FW to latest version, was on 1.04a:04 - 1.06:04 has a correction, SC687 may occur or the machine may stall with "Copying..." displayed when a copy job is performed following recovery from Energy Saver Mode. The machine would stall before the engine update but would not pop the error until after.
    • Reseated all connectors on the BCU and controller
    • Replaced the BCU
    • Replaced the Controller
    Google doesn't return many results, however I've found a slim few suggesting HDD.
    HDD, NVRAM, ADF Board/Cable?
    Looking for some suggestions/opinions of where to look next.
    Thanks!
    • 37532
    Re: MPC4502 SC 687
    Goose's Guide did not have SC 687 for this model. Searching it for all models, I came up with a few things to try.
    For the MP C3500, disconnect the DF. If the problem goes away, replace the DF main board.
    For the MP C6000, SP 5832-002, reformat HDD IMH. IMH I believe is IMage Handling. I would also try IMH memory clear SP 5801-004. Before doing any memory clear, I would backup the NVRAM. Before replacing NVRAM, I would back it up, do a full memory clear, and then restore from the backup. I would also print the Non-defaults in case the NVRAM does not backup properly.
    • Zeldaman
      • Mar 2011
      • 946
      Re: MPC4502 SC 687
      Hi there!
      Cleaning the contacts of the DIMM is worth a try.
      Greetings...
      • Bantams
        • Jun 2012
        • 603
        Re: MPC4502 SC 687
        I've had a broken Finisher Cable cause this once.
