C700ex pro does not see the finisher, if i dis engage the fin and run copy it spits it out, no jam indicated, witch means it doesnt know the fin is there, the fin goes through its prompts, but with it engaged, it jams at the mouth showing jam in e section witch means it didnt clear that section, but we know this, I have a sr 4010 and a sr5000 but im not sure the 5000 is the c model but never the less, when you open the fin door it should see its open and send an alert, no worky
so how do I check this connectivity? Im going to replace the connector, but i checked it its connected,but i suppose it could have pin damage. If the fin isnt recognized then i can up date the firmware to the sr5000 to make it a c.
any ideas?
any ideas?
