MP C300 Print Interleave
  • mikadonovan
    • May 2008
    • 2931
    Hi, All. I have a M026 that interleaved an incoming fax and print job when they were occurring simultaneously. Print priority is set to Job order and firmware is up to date. Anyone see this before?
    NEVER ASSUME ANYTHING
  • halbrandenburg
    Bypass Tray Expert
    • Sep 2011
    • 92
    Re: MP C300 Print Interleave
    It has been reported but never observed, nor has a customer been able to recreate this phenomenon for me.
    How often does it happen? Is it a busy real estate office?
    • Gift
      • Mar 2011
      • 2459
      In some software enviroments print jobs that seem multi-page are actually generated as single pages - in this case there's no chance for the MFP to detect the proper job-end.
      • mikadonovan
        • May 2008
        • 2931
        No, It's a CPA office. She is an excellent User and I believe her. Gift may be right . She does use special accounting software that may be the root of the issue.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          MS Office prints that way.
          If you ask for 5 copies of a Word doc, it's 5 separate jobs.
          AFAIK, all products in the suite behave the same way, although the only other one I can verify is Excel.
          • mikadonovan
            • May 2008
            • 2931
            You would think there would be a setting in the MS software to change that. Is this across the board, or just on Ricoh boxes?
              • 37560
              Check the Printing Preferences in the driver settings. If Ignore Application Collate is not checked the software will send the document the document x number of time where x is the number of copies wanted. If it is checked, the software should send the document once with instructions to print it collated x number of times.
              • nmfaxman
                • 1702
                Are you setting the print driver to LPR with the queue as lp?
                Sending print jobs as raw goes to memory where the fax option sends the print.
                Setting LPR sends print jobs to the HDD as a spool and waits till memory is clear before printing.
