pro 1356ex vs mp1350
  • ali.alhaj
    • Mar 2013
    • 34
    Hi all
    I have qustion about these machines pro 1356ex & mp 1350 what deferance beween these machines specialy machine life, duty cycle.
  • PinevskiS
    • Jul 2009
    • 283
    Re: pro 1356ex vs mp1350
    Originally posted by ali.alhaj
    Hi all
    I think is software and f/w different.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      the 1356ex is a newer version of the 1350. I believe frimwar maybe different, life and volume, supplies pretty much the same......
      Mystic Crystal Revelations
        • 37490
        They share the same Service Manual and Parts catalog.
        • Imprestik
          • Aug 2012
          • 297
          As mentioned about, they are both the same speed, the MP1350 firmware should be updated to the Pro1356ex firmware
          PM cycles are the same at 500K, PM parts are the exact same, peripherials are the same, electrical components like boards are different
          but the only physical difference is the duplex unit and exit unit. They have changed all the rollers from the MP1350 to the Pro1356ex and you will notice there are more ventilation holes in the units of the Pro1356ex to allow better air flow.
          In saying that, I have upspec'ed all my MP9000/1100/1350's and Pro906/1106/1356ex devices with Pro907/1107/1357ex duplex and exit units as they have even better rollers in them and allow for even better airflow. Makes a massive difference in those long runs and as I call it raining in the fusing exit is now non existant.
          • hussam
            Engineer
            • May 2014
            • 11
            MP1350 & Pro1356ex Target Volumes
            Average Monthly Volume (Target): 300k
            Maximum Monthly Volume (Recommended): 1,000k
            Monthly Duty Cycle (Peak Volume): 1,900k
            Unit Life: Approximately 60,000k or 5 years (whichever comes first)
            • anothertech
              • 1769
              You will not be happy if you try to run it at these volumes!
