Ricoh 2075, RADF
  • kalaris
    • 70
    Ricoh 2075, RADF
    Hi!
    Ricoh Aficio 2075, by inserting a file in duplex on the document, with each jam after the return of the original jammed the machine ejects a blank sheet and then goes to work. To avoid unnecessary waste of paper do you know if there is a setting or a change from firmware to avoid this problem? I think that is common to all these models because I've tried with other machines is the problem repeats itself. (sorry for the bad translation) Thanks
  • sandmanmac
    • 3981
    Re: Ricoh 2075, RADF
    Originally posted by kalaris
    Hi!
    Boom! There's your answer!
    Here's a CRAZY idea...why not fix the RADF ??
    • Iowatech
      Not a service manager
      • 3930
      Hi!
      If I understand you correctly, you should clean the sensors in the ADF as it sounds like it is detecting the wrong paper size.
      Might not hurt to replace the feed belt and the separation roller in the ADF as well, although the annoying squeaking noise should be pretty evident if you need to do that.
      • kalaris
        • 70
        Why is the client who has some of these machines in self service and the originals are often damaged or perforated, and the RADF also in good condition can clog and create that problem.
        • Iowatech
          • 3930
          Pictures, please.
          In the mean time, best guess: originals stapled together. If you have a magnetic tool, go fishing for staples. Based on the information so far I'll bet you'll catch some.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Did I forget something or doesn't the 2075 have a single pass duel scan ADF and not an RADF?? Troubleshooting would be a bit different if, troubleshooting with the wrong model info............. any original jam or paper jam codes on the SMC logging data??
            Mystic Crystal Revelations
              • 37449
              This is correct. In answer to the original question: No there is no setting. If the original jams after lead edge has reached the registration sensor, the copy process has been initiated and a blank page is printed. The way to reduce wasted paper is to diagnose and correct the cause of the jamming.
              • Tonerbomb
                • Feb 2005
                • 2589
                jam codes and logging data would be helpful..........
                • kalaris
                  • 70
                  Sorry, maybe I am badly explained. The problem is not the jam due to problems with grip paper, but what causes the release of the white paper after each jam RADF once resumed work, jams that can be caused by some original punctured or damaged. Not being able to always control the quality of the original paper jams may occur and the consequent waste of paper. The question is, if there is a change of firmware, or a setting to prevent this. Thank you
                  • Codex
                    • May 2008
                    • 701
                    Hello to all!
                    Sorry that i answer in italian, but i think i can explain it better.........
                    Ciao, se non ho capito male quando la macchina s'inceppa esce un foglio bianco? Questo e normale e non ce nessun rimedio o aggiornamento Firmware per evitarlo, e dato dal fatto che nel momento che la macchina inizia a leggere da ADF gia parte il foglio dal cassetto, quindi la macchina in quell momento non sa ancora che si inceppera, quindi se poi si inceppa fa uscire un foglio bianco.
                    Memento Audere Semper
                    • Tonerbomb
                      • Feb 2005
                      • 2589
                      Originally posted by Codex
                      Hello to all!
                      From google translator:
                      Hello , if I understand it when the machine jams out a blank sheet of paper ?
                      This is normal and there is no remedy or update firmware to avoid it,
                      and the fact that when the machine begins to read from ADF already part of the paper from the tray,
                      then the machine at that time not yet know who will jam , then if he gets stuck brings out a blank sheet of paper .
                      You would be correct if the scanning has already started and paper feed has began,and the original jams
                      the blank page will feed out of the machine, and there should be an original jam displayed.... Just the way it is...
                      • Codex
                        • May 2008
                        • 701
                        it happens when the jam occurs in the second paper sensor....then a blank sheet comes out......i'll tried this today with an MPC 2500...........and thanks for the translation
