Hi!
Ricoh Aficio 2075, by inserting a file in duplex on the document, with each jam after the return of the original jammed the machine ejects a blank sheet and then goes to work. To avoid unnecessary waste of paper do you know if there is a setting or a change from firmware to avoid this problem? I think that is common to all these models because I've tried with other machines is the problem repeats itself. (sorry for the bad translation) Thanks
