- Exists_IP_AddressI have a machine MONITORED by an @Remote appliance, that when I try to set the copier to MANAGED mode, I get the message "@REMOTE_RESULT_EXIST_DEVICE_IP"
I have tried removing it and letting the appliance rediscover, managing at the appliance. all with the same results.
There is NO other device showing with that IP
Ideas anyone?
@Remote error Exists_device_IP
Tags: None -
Re: @Remote error Exists_device_IP
This might be really stupid, and if so sorry about that, but it sounds a little like something else on the network has taken over the network address of that MFD, and @Remote has set itself up for that.Comment
Assuming your a guru with @remote.
You may like to try a packet sniffer program ,some thing like "WireShark" ?
See if you are getting MIM or DOS attack interfereing with MFD.
I haven't had a lot to do with @remote. The old boss would'nt let me play with it...
HTHInauguration to the "AI cancel-culture" fraternity 1997...
โขโขโขโขโขโข โขโขโข[ยง]โข |N | โฌ | o | M | ฮ | t | ฯ | ยก | x | โข[ยง]โขโขโข โขโขโขโขโขโขComment
Part of my challenge is that the appliance is approx 2000 miles from the machine. So I have to rely on the client to check on what i ask them to.Comment
I am assuming that you are near the appliance location and not the machine and therefore need to rely on the client to provide you with information concerning the machine. Have you had them try configuring the machine to a different IP address? What type of connection is there between machine location and the appliance location? From the appliance location, can you access the machine using either WIM or FTP to check settings? Will the client allow you to access a computer at each location using Goto My PC or similar service? It seems that all I can come up with are questions at this time but maybe one of them will cause to think of something to try.Comment
Thanks all for your answersComment
