Priction pad for RICOH JP1250
  • PA3040
    • Jun 2014
    • 171
    Dear All,
    As you all well aware The RICHO JP 1250(5308) Copy printer series was discontinued, therefore we have a issue with Friction pad unavailability, Please advice compatible machine model or part number that we can use it Friction pad for JP1250
    Thanks In advance
  • laitang
    • Nov 2012
    • 627
    Re: Priction pad for RICOH JP1250
    C231 2861
    • PA3040
      • Jun 2014
      • 171
      Originally posted by laitang
      C231 2861
      [ATTACH=CONFIG]26273[/ATTACH]
      Dear laitang
      Thanks for the reply
      I should have this pat number and Ricoh does not supply any pats on this part number so what I need to know is what is the alternative pat number for this that we can order from ricoh
      Thanks in advance for help
      PA3040
        • 37532
        Ricoh assured parts availability for the JP1230 ended in January of 2010. If the same part is not used in a new model, by now Ricoh has depleted their inventory. You could try the C238 2845 Separation Pad for the JP 3000 and JP 1235. Assured parts availability for them ended January of this year so they might still have some. Picture in the parts catalog look similar. The only other options are:
        1. Try cleaning the old pad using grit cloth or emery cloth to roughen the surface
        2. Purchase from an after market supplier such as Precision Rollers
        3. Replace the dinosaur. This is the best option as you are going to start having other parts fail that are no longer available.
        • PA3040
          • Jun 2014
          • 171
          Dear slimslob,
          Thanks for the reply and advice
          We have JP3000 too and I checked that Friction pad which is not identical for JP1250 series. Please advice if you know any successor model of JP1250
          Thanks in advance
            • 37532
            The C237 JP1230 was replaced by the C238 JP3000 which was replaced by the C248 JP1235 which was then replaced by the C267 DX3340. They are all currently covered in the same service manual and parts catalog. There are minor differences from one to the next.
            Current Ricoh models are the DX 3343, the DD4450 and the DD6650.
            • PA3040
              • Jun 2014
              • 171
              You may correct but all are different with C231 ... Am I correct?
