ricoh mpc2500 eror sc670,urgent
mpc2500 -sc670
Re: mpc2500 -sc670
From SM:
SC670: When the main power is turned on or the machine starts warming up from energy-saving mode, the controller does not receive a command signal from the BICU.
- Loose connection
- Defective controller
- Defective BICU
1. Check the connection between the BICU and controller.
2. Replace the controller.
3. Replace the BICU. -
Re: mpc2500 -sc670
I also face same issue in same model mpc2500 it was resolved by replacing hard disk
You also try this may be it is fruitful to youComment
