mpc2500 -sc670
  • tullio
    • Feb 2012
    • 268
    mpc2500 -sc670
    ricoh mpc2500 eror sc670,urgent
  • laitang
    • Nov 2012
    • 627
    Re: mpc2500 -sc670
    From SM:
    SC670: When the main power is turned on or the machine starts warming up from energy-saving mode, the controller does not receive a command signal from the BICU.
    - Loose connection
    - Defective controller
    - Defective BICU
    1. Check the connection between the BICU and controller.
    2. Replace the controller.
    3. Replace the BICU.
    • sandmanmac
      • 3983
      Re: mpc2500 -sc670
      FIRST:
      Invest in a damn Service manual!
      Then:
      Do something /ANYTHING to help yourself!
      Next:
      Ask for help if you still need it
        • 37553
        Re: mpc2500 -sc670
        Originally posted by sandmanmac
        FIRST:
        Then:
        Next:
        I agree, 83 posts and still has a Red card and no Rep points.
        • sandmanmac
          • 3983
          Re: mpc2500 -sc670
          He can thank me for most of the red cards.
          Probably half of the posts are just like this- including another SC-670 post.
          It drives me nuts!
          • mdfurqan2012
            • 194
            Re: mpc2500 -sc670
            I also face same issue in same model mpc2500 it was resolved by replacing hard disk
            You also try this may be it is fruitful to you
            • khaled_abosere3@yahoo.com
              Head technical support
              • Mar 2012
              • 171
              Re: mpc2500 -sc670
              FIRST:
              Then:
              Next:
              Be patient with the others.
