MPC2800
  • GeorgeBest
    • Jul 2009
    • 526
    MPC2800
    Hi,
    Had a customer complaining about the colors on this machine . .
    He was right, red became purple, only yellow was good.
    Did the color calibrition, but the test page came out total wrong !! Could not calibrate ! Only yellow was correct.
    eventually changed the complete PDU units Magenta and Cyan. (with DV unit)
    Then did the calibration again, this time is was good.
    So, with good hopes, I left . . .
    But, however, customer called today and the colors were again not good, same symptoms
    Anyone an idea here ??
    Thanks in advance
  • Moza
    • 232
    Re: MPC2800
    Originally posted by GeorgeBest
    Hi,
    Thanks in advance
    I would check the waste toner collection is not blocked causing contamination on the ITB belt. It makes sense that it was fine after replacing the PCDU's as they wouldn't have been contaminated straight away.
      • 37529
      Re: MPC2800
      Dirty laser shield glasses. Laser shutter sticking.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Re: MPC2800
        Have you done a ProCon? What are the results?
        • sandmanmac
          • 3981
          Re: MPC2800
          George has never been really big on returning with Updates - or "Thank you's"
          • khaled_abosere3@yahoo.com
            Head technical support
            • Mar 2012
            • 171
            Re: MPC2800
            Sorry! what do you mean by a procon?
            • anothertech
              • 1771
              Re: MPC2800
              oh boy, here we go!
              • GeorgeBest
                • Jul 2009
                • 526
                Re: MPC2800
                So you checked my history Ruben . . .
                Don't waste your time, its not worth it.
                Busy working (I'm alone) and not always time for responce
                We've swapped the machine with the color problem, it returned to Ricoh
                for your information . . .
                Greetz
                • Polo-022
                  • Sep 2007
                  • 486
                  Re: MPC2800
                  ...and who payed that bill George? Two complete PCDU's!!!!!
                  I think that Moza's avatar says something...
                  • GeorgeBest
                    • Jul 2009
                    • 526
                    Re: MPC2800
                    Why bother . . . . .????
                    • Herostrat
                      • Oct 2012
                      • 220
                      Re: MPC2800
                      I'll take a wild guess and say it's toner...some chineese toner messed it all up,you swaped PCU's and it was all good untill developer units spent toner they had and started using toner from the bottles...now u swaped entire machine.
                      I hope that new machine is using real deal toner?
                      Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
                      • GeorgeBest
                        • Jul 2009
                        • 526
                        Re: MPC2800
                        Hi,
                        Yes, it does.
                        Greetz
