Networking expertise
  • sandmanmac
    • 3996
    [Electrical] Networking expertise
    Hi guys/gals
    I need your expertise/ advice on what mat be a stupid question.
    A customer of mine just moved their machine MP C2500 and called me in to re-connect it. I discovered that they damaged the TCP/IP port insides and I can't get a connection. I tried for about an hour to straighten out the 'prongs' (or whatever they're called) inside it with no luck.
    I'm pretty decent at connecting stuff and setting up small Workgroups, etc., but honestly, my comprehension of how all the data is transmitted is really quite a mystery to me. That's the REAL IT people's jobs
    So here's my question: Can I use the USB port with one of these print servers below (or similar) and simply configure it as I would normally? I'm not concerned about printing issues, it's the SMB scanning that I'm having doubts about.
    My gut tells me it's a no-go, but I'd appreciate any feedback.
    If not, I guess it's new Controller time for them . That puts the cost up!
    For more info:
    Buy the Iogear GPSU21 USB 2.0 Print Server at TigerDirect.ca
    • 22994
    Re: Networking expertise
    I don't see why not. I've installed plenty of similar devices, usually in cases where the enduser has multiple networks, and requires multiple network interfaces. =^..^=
      • 37738
      Printing should work fine. If I remember correctly, the MP 2500 does not support USB scanning, or if it does, it is only TWAIN scanning from the computer connected to the USB.
      If you are good with a soldering iron and the damage is only to the connector, you might be able to replace the CAT 5 connector on the board. Bear in mind that the board is most likely a multilayer design with plate through holes, so unsolder very carefully.
        • 22994
        I've been able to replace connectors on the single layer boards, but not multiple layer. the last was a Canon which pinned out out OK on the workbench, but still would not connect to the network.
        Alas, you take your chances. =^..^=
        • sandmanmac
          • 3996
          Just to clarify Slim, It's an MP C2500, but I'm not interested in USB scanning, I'm wondering if SMB scanning would be possible once this 'adapter' is installed.
          And I'm not going to mess with the soldering (at least until I've made a deal to exchange with them) or I'll be blamed for anything else that goes wrong
            • 22994
            Negative on that. You'll need original network connection for that. =^..^=
              • 37738
              SMB scanning uses the on board port controller in the MP C2500. We had one that had the port controller go bad. You could ping it, you could access WIM, you could not print or scan. Had to replace the control board.
              • sandmanmac
                • 3996
                I had a feeling my gut was right. It was just a thought that came to mind as I struggled to get the pins straightened out.
                Thanks guys!
                • NeoMatrix
                  Senior Tech.
                  • 3510
                  Apart from the physical damage to the net connector.
                  Is the print/scan VM card in the correct slot and works okay?
                  • sandmanmac
                    • 3996
                    Oh yeah, it's all good.
                    The machine was working great up until they moved it yesterday. The owner even admitted to possibly 'stretching' out the ethernet cable when he was pulling out the machine.
                    I have it printing Via USB for now until I take them a replacement Controller tomorrow
                    • MitchD
                      • Oct 2012
                      • 164
                      Have you thought about doing a exchange with Hytech? I have had a few controller's with this same issue you are having and they fixed me up for about a third of the price on a new unit from Ricoh
                      "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
                      • sandmanmac
                        • 3996
                        I appreciate the advice.
                        One of the great benefits I enjoy in this area, is my close proximity and long term relationships with a couple of very large equipment wholesalers.
                        I help them out with issues from time to time, and let's just say, they look after me very fairly when I'm in a bind.
                        The unit's been swapped, and everything's working beautifully again.
