MPC 3000 error code SC 565
  • Tamyiapsoon
    • Dec 2010
    • 80
    i already change hot roller thermistor and F/Belt thermistor , after print few copy sc565 error code come out again , someone can help , urgent ! Thank You and appraciate .
    • 37514
    Re: MPC 3000 error code SC 565
    Check the thermostats. Open pressure roller thermostat will give this type of error.
    • Polarbear
      • Feb 2012
      • 1070
      This series of machine sometimes gets to a point where the only solution is a new complete fusing unit. There is no explanation for it, but if you search the site, you will see this remark elsewhere also.
      All the parts + labour ends up costing more than the new fuser anyway! Not to mention the angry customer!
      Press the GREEN button!!
      • lef3pap
        • Jan 2012
        • 32
        I had the same exact issue.What i did is this : i replaced everything on the fusing unit.Thermistors, hot roller,the belt ,the main jack of the fuser ... Everything.After a few minutes sc 565 appears.So as the previous member said i think that the only solution is replacing the fusing unit.Of course i tried one other fusing unit from another machine and the code didn't appear.I lost many days so just change the hole unit
        • CrapAimer
          • 296
          Check the thermo fuse under the pressure roller. and also by swapping fusers from another machine will cure fault
          • mikadonovan
            • May 2008
            • 2931
            This is the fix.
            NEVER ASSUME ANYTHING
            • Tamyiapsoon
              • Dec 2010
              • 80
              Thanks all friend of you , i have find up is thermostat open cuicuit , thanks full for sharing your exprilliant.
              • masyuk
                • Nov 2014
                • 15
                I also facing this issue. I try to change heating lamp. The problem solve..
                • lukas2576
                  I had the same problem with error code sc565, I have interchange the entire fusion group with others 2 used group with the same result.
                  So I tried many changes inside the temperature values, but nothing...... till I tried to make the ricoh, not in stand-by, but stand-off (service manual explain the difference at page 820) and it works...... (stand-off after 5 min).
                  Anyones else tried to do it???
                  • rednecktech
                    • 54
                    Check thermostats!!
                    Sent from my XT1254 using Tapatalk
                    • coolgreen
                      • Sep 2012
                      • 7
                      open thermostats, can take several sc . Check all first ! Otherwise , move away thermistor slowly fusing Belt. I guess problem is sponge roller damage and it havent tension with Belt correctly.
