MP C2003 USB Printing
  • PA3040
    • Jun 2014
    • 171
    Dear all,
    We have MP C2003 Machine that have Direct USB printing Feature but Some USB pens do not support. Please advice
  • skynetto
    • Sep 2012
    • 257
    Re: MP C2003 USB Printing
    404 Not Found
    Change USB Device
    • PA3040
      • Jun 2014
      • 171
      Originally posted by skynetto
      404 Not Found
      Change USB Device
      Dear sky thanks for the reply
      Can we use it with out change?
      • skynetto
        • Sep 2012
        • 257
        USB flash memory devices and SD cards are supported for direct printing. However, certain types of USB flash memory devices and SD cards cannot be used. For details, contact your sales or service representative.
        Have to contact Ricoh or your sales or service representative.
          • 37652
          I believe that there is a size limit for memory devices that can be use. Try staying with 4GB or smaller. Also, you can only print certain file types; JPEG, TIFF and PDF. You can only have one memory device installed at a time.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            These machines are touchy as all get out when it comes to jump drives.
            Pretty sure it can only be formatted as FAT, and not FAT 32.
            Not to mention that some brands just flat out don't work no matter what you do with them.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Trial and error my friend....find a brand and model that works and buy a few.
              • Choro1dal
                • Jun 2008
                • 176
                SD cards supported up to 2GB
                No size limit documneted on USB drives, though they must be formatted FAT or FAT 32 only. They cannot have any form of encryption or security insatlled and must plug directly into the MFd's USB port (no fly leads).
                • PA3040
                  • Jun 2014
                  • 171
                  Thanks for the reply
                  What I did not check that formatted file system and any security installed Driver and I will double check and confirm
