Ricoh MP C4503 print quality problem
  • EricToner
    • Sep 2013
    • 5
    [CQ] Ricoh MP C4503 print quality problem
    Hi Everyone
    I'm not a Ricoh technician... but any advice would be greatly appreciated. We have a Ricoh MP C5502 and MP C4503 machine both with the same print quality problem.
    Please see the attached picture, we printed from a PC and USB and had the same results. We updated the firmware on both machines and changed out print units with no success. Thank you!
    • 37495
    Re: Ricoh MP C4503 print quality problem
    Have you ran Auto Color Control? User Tools - Maintenance - Auto Color Control.
    • Elmo
      • Feb 2010
      • 541
      Is the problem just with this particular image or all colour prints
      what is the image like when printed in black only
      I Used To Live To Fix Things Now i Fix Things To Live
      • EricToner
        • Sep 2013
        • 5
        It's not this particular image, it happens with all color prints. I just tried black only on the 4503 and it's also has the problem. Attached is the BW sample print
        We tried color calibration and ran auto color control without any luck. Another Ricoh technician is coming to look at these machines, possibly today, and hopefully will have some luck this time diagnosing. Thank you for the help!
        • Elmo
          • Feb 2010
          • 541
          From the samples it looks like a black pcu issue poss drum/developer
          • EricToner
            • Sep 2013
            • 5
            Ok, we changed all cmyk drum units approx 4 days ago. print quality was fine for 2 days and then the problem came back, strange.
            I will post if our Ricoh technician solves this for us today and what he found. Thanks again
            • Elmo
              • Feb 2010
              • 541
              Was it the complete pcu's you replaced or just the drum's
              did you run the developer intialise after replacing them
              you could run Forced Toner Supply in sp mode
              then try a print and see if the quality has improved
              • Dragord
                • Sep 2014
                • 5
                Is this prints and copies? Is it a driver fault, try pcl or rpcs
                • Cipher
                  It's not easy being green
                  • May 2006
                  • 1309
                  Looks like some kind of image processing fault, possibly driver or application related.
                  The fact it's occurring on two different model ranges would suggest to me it's not a mechanical issue.
                    • 37495
                    I hadn't thought about that. It could be some type of malware on the computer. If by USB Eric meant Print From Memory Device, I would take the USB drive to another that has proper malware protection and see if it displays properly there. If it was just was just network or USB cable printing, I would say it might be the wrong driver. If using the Microsoft Windows "Ricoh Class" driver or Ricoh's "PCL6 Driver for Universal Print", download and install either the regular PCL6 driver or the PCL5 driver. In some applications, the PCL5 driver gives better color.
                    • billm
                      • Jun 2012
                      • 50
                      I have the exact same problem with a mp c5502b color black is missing updated firmware to 2.14 no change when you look at the file in the preview for the thump drive it looks the same as it prints color washed out internal test is good calibration good pcu and dev new
                      lost with no where to turn
                      • NeoMatrix
                        Senior Tech.
                        • 3513
                        Are you using a completely different scanner(another office) away from these two machines, and just sending print jobs to these two machines ?
                        It look likes someone has set "Use windows colours only" from a paint program 24bit down conversion out to the print job.
                        Have you compressed the colours down from 24bit(16million) to 256 colour palette ? Are you storing in 24bit Tiff format and sending it to the printer(s) in *.GIF or *.PNG format ?
                        • billm
                          • Jun 2012
                          • 50
                          my test from my lap top was a pdf internal print test good
                          • Zaxxon
                            • 608
                            You are asking in a total different model thread?
                            May I ask why?
                            Please start you post with brand, model, problem.
                            • billm
                              • Jun 2012
                              • 50
                              I was hoping that this thread had come to a resolution because I am having the same problem. with a lot of hits more people have seen this thread.
                              I did post my whole scenario in a different thread with examples
                              have you seen this before
