Mp3350 light copy
  • mrfuser
    • 1617
    Mp3350 light copy
    Prints fine. Use adf and op side of copy is light and put on glass and get non op side light.
    any adjustments?
    thanks
    kelly
  • copyaction
    • Oct 2007
    • 991
    Re: Mp3350 light copy
    try lifting the front left side of the scanner.
    • logrady2331
      • Feb 2011
      • 301
      copyaction is correct. Scanner bent down on front left corner. Happens when the machine gets moved/delivered and the scanner is used as a handle.
      • vstar
        • Aug 2007
        • 176
        Check PM count. If it is time or close this can cause the same thing.
        Cameron
        • mdfurqan2012
          • 194
          any adjustments?
          thanks
          kelly
          Scanner bent from front left side during shifting or use as a Handel.
            • 37490
            Can also result from leaning on the corner.
