sg3100snw scan to gmail
  • garryayling
    • Jan 2011
    • 21
    need help my printer has been ok for ages scanning to gmail but its just stopped. I can do a connection test but when I scan it fails to connect to server. Im using aspmx.l.google.com as theSMTP server without authentication or encryption.
    ive tried
    SMTP Server: smtp.gmail.com
    Port: 465
    SMTP Authentication: Set to <On>
    SMTP Authentication Email Address: <Your full Google Apps email address>
    Username: <Your full Google Apps email address>
    Password: <Your Google Apps password> Use SSL: On
    but it wont except the amount of spaces I need to input my email address.
    Does anyone have any idea how I can get the correct settings.
  • ccchuah
    • Mar 2009
    • 153
    Re: sg3100snw scan to gmail
    why not set up your email with gmx.com
    SMTP server : 74.208.5.1
    Port : 587
    SMTP Authentication Email Address: <Your full gmx.com email address>
    Username: <Your gmx.com email address>
    Password: <Your gmx.com password>
      • 37062
      There is a possibility that Google has joined the crowd requiring TLS instead of SSL. Most MFPs currently do not support TLS. As long as you only want to send to other Google email accounts, either in your Google Apps domain or @gmail.com, you can use Google's port 25 SMTP server, aspmx.l.google.com. This is what I have used for older equipment that does not support SMTP over SSL.
      Set up a device or app to send email through Google Workspace Who this article is for This article is for Google Workspace administrators who want to send email from devices or apps in their
      • garryayling
        • Jan 2011
        • 21
        Thanks for the reply but if you read my original message I said ive been using the aspmx.l.google.com and its not working now. im trying to find out why and a fix. Thanks for your help.
        https://support.google.com/a/answer/176600?hl=en
          • 37062
          You might be having a problem with the ISP blocking port 25. If your internet connection has been changed and you are now using a Motorola NVG 510, there is a setting in that for port 25, default is block port 25. Have you tried using smtp-relay.gmail.com. It is referenced in the link that I attached previously.
          • Iowatech
            Not a service manager
            • 3930
            Actually, it looks like aspmx.l.google.com is offline, at least according to this:
            Is It Down Right Now? Website Down or Not?
