MPC 3003 java update
  • rhe
    • Feb 2013
    • 51
    [Misc] MPC 3003 java update
    Dear All
    any idea for mpc 3003 java update,it is standard on machine.No card on any slot.any update......
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: MPC 3003 java update
    Java now resides on the controllers flash memory to speed things up a little, the current version is v11.23.00 / D1475579M.
    You extract the sdk folder to the root of a suitable SD card then put it in the normal service slot and then power on.
    It should automatically start the update once the rest of the MFD modules have loaded up.
    After 3-5 minutes you should see a message in the bottom corner, java updating... jave update has completed... etc.
    • copier tech
      • 8165
      Is the Java the same version for all the Metis range?
      Also what is the java update tool for!? Thanks
      • Cipher
        • May 2006
        • 1309
        The Metis range is at the same version level (11.23.00) but the Java files are slightly different depending on the model.
        MPC 2003 (SP/ZSP) / 2503 (SP/ZSP) / 3003 (SP) / 3503 (SP) - D1475579M
        MPC 3003 / 3503 (ZSP) - D1465579M
        MPC 4503 / 5503 / 6003 (A/SP) - D1495579L
        MPC 4503 / 5503 / 6003 (A/ZSP) - D1485579M
        SP = Ricoh Legacy Operation Panel
        ZSP = Smart Operation Panel (Android).
        The ' Java VM Update Tool ' is basically the Java update files bungled into a self-extracting archive to be updated via a SD card.
        (Run the .exe and it will prompt you to enter the drive letter of your SD card, then it will proceed to extract the files there).
        The ' Java for eDC ' is the same Java update accept it's installed over the network via the Remote Install Manager.
        Print off the Self-Diagnostic Report to confirm versions.
        • copier tech
          • 8165
          Great response, many thanks! 😃
          • rhe
            • Feb 2013
            • 51
            Dear Friend
            thank you for your update.c
            an you tell more abou it .i download file for mpc 3003 with file name D1475579M_upd.exe when i extract file it is like D1475579M_upd.In the sub folder i can see folder name ver11.30.00_FM_1.when i open this folder there is sdk folder ,i mean this folder you are saying to copy in sd card and what will be sequence like romdata -then -product code -then sdk file or other way to copy that.
            Thank you for reply
            • Debs1964
              • Oct 2010
              • 1693
              Just copy the SDK folder onto your SD card, no Romdata folder or anything else, if you open the SDK folder there is an update folder, there is another SDK folder within the update folder, make sure it's the first SDK folder you copy across.
              When you put your SD card into the machine, it extracts and installs java with no input from you, wait until you see the message "success", then power off and remove your SD card
              There are 10 types of people in this world, those who understand binary maths and those who don't
              • rhe
                • Feb 2013
                • 51
                Dear Friend
                Thank you very much.
                • rhe
                  • Feb 2013
                  • 51
                  Dear Friend
                  i update the java firmware for MPC 4503 and now machine showing error SC 636-01.Machine has CAP V2 and enhanced locked print NX installed.i can see on machine panel it is showing cap not installed and card reader not selected by machine.Any help
                  • impetus73
                    • Mar 2012
                    • 75
                    Remember that updating the java, puts the heap and stack settings back to default. Check their values before updating, and set them correctly again after the update is done.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      ... 2 months later :>P
                      For what it may be worth, with Java 10.x, 11.x, and 12.x, you MUST uninstall and reinstall these apps.
                      Ricoh has always said that needed to be done with any app and version of Java, but we were always able to get away with updating the Java and nothing more.
                      Alas, that is no longer the case.
                      I'm not sure if some apps still work without being reinstalled, but I can say that CAP, ELP, and GSNX all need to be re-done. Been there, got the T shirt.
                      • impetus73
                        • Mar 2012
                        • 75
                        If you install the apps in the FM area, not on the java card, I don't think you have to reinstall them.
                        • kopirmaster
                          • Apr 2011
                          • 70
                          in wich port i have to put the sd card i tray with only sdk folder i all 3 ports with a panel port and cant instal the java update pls help
