Mp6001 df jams and feed noises
  • davydoodledo
    • 21
    Which one way gears have people been replacing to eliminate feed in jams?
  • mikadonovan
    • May 2008
    • 2931
    Re: Mp6001 df jams and feed noises
    I don't know about one way bearing problems on this model, but if the transport rollers are not driving, try this.
    NEVER ASSUME ANYTHING
    • davydoodledo
      • 21
      Thanks. but all ready done that along with playing with belt tension
        • 37503
        Have you tried cleaning or replacing the ADF feed components? Give us some information as to the jams: jam code(s), what you have observed when testing the feed.
        • techsass
          • Dec 2010
          • 248
          I've had a run lately on the 1-way that the feed belt rides on causing feed in jams. So far popping the E-clip and dousing some degreaser on it has taken care of the problem. I haven't had any noise, so it may not be what you're seeing.
