Ricoh MPC5000
  • GeorgeBest
    • Jul 2009
    • 526
    Ricoh MPC5000
    Troubles with ADF original detection.
    A4, A3 works fine when feeded in the ADF.
    But, feeding a A4r (landscape) machine gives an error and ask for a A5 js paper ?
    Cleaned the sensors, no effect.
    Is there an adjustment here ? Can't find it in sm
    Thanks in advance
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Ricoh MPC5000
    Sounds like SP 4303 = 1 (A5 detect mode is on for banking machines etc.)
    • GeorgeBest
      • Jul 2009
      • 526
      Re: Ricoh MPC5000
      SP4303 was fine . .
      changed The sensors on the ADF trap (3 x) !!
      no results !
      still the machine says that it needs a B5 jis format paper ?
      anyone a clue here . . . Thnx!
        • 37560
        Re: Ricoh MPC5000
        If the sensors you put on were new, I would say the harness the goes to them. If the stop for the feed table is missing or broken, the table can be lifted high enough to pull the connector to the ADF PCB partially loose. You can use SP 6007 to check the sensors.
