LD 145 with SC402
  • rthonpm
    • Aug 2007
    • 2849
    LD 145 with SC402
    All,
    I've got an LD 145 that keeps throwing random 402 codes. I looked at all the transfer belt connections and the voltage board for the PCU and belt, and they all test fine. The only thing I can see out of whack is that someone removed the drum and dev stay in the front. I'm hoping it's just as simple as replacing that to keep the drum in place, but defer to those out there who have seen this problem before.
  • Jomama46
    • 2900
    Make sure that the two springs for the transfer contact are in place.
    sigpic
    A+; Network +; PDI+
    • verderacer
      • May 2008
      • 158
      I have also seen the center metal tab has debris, usually a build up of toner baked on the end of the roller, so that the roller does not always make good contact with the metal tab inserted at the end.
      Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
      MCSE/CCNE/ENS and other crap...
      • Serviser
        • Jun 2007
        • 16
        I have this problem at same mashine, it`s all works fine, but after many troubles whit this, I find that main motor has lose there power. replace motor, and solve the problem.
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          Change the clutch behind the flywheel.
          # 9- AX21 0081 Transfer Unit Clutch
