firmware issue
  • Riyadh hossain
    • Aug 2025
    firmware issue
    For firmware storing needs USB stick 1GB or less and FAT format .But now 1GB or less usb stick is not available in market ,
    Have any alternate way to store firmware files for firmware update????
    Sometime I use 4GB,FAT32 format but all time it does not work and vanish automatically, when I insert in pc,pc show need to format before using this device . Have any solution about USB stick for firmware update????? please help
    • 37609
    Re: firmware issue
    To my knowledge, you have to use a SD card to do firmware updates on most current Ricoh MFDs. Depending on the age of the model, you may be limited to either 1GB, 2GB or 4GB. These can be found on the internet if you can not find anything smaller than 8GB locally. If you do have a machine that uses USB sticks, you can also find them on the internet.
    As an alternative, you can download the .rfu version of the update and install it using WIM. No, you can not change the extension of normal firmware update files.
    • Iowatech
      Not a service manager
      • 3930
      Re: firmware issue
      Ricoh equipment firmware updates are not done with USB sticks.
      Please stop acting like an imbecile. I'd prefer to think that you are not one.
      • NeoMatrix
        Senior Tech.
        • 3513
        Re: firmware issue
        If you are having problems copying firmware to an SD card.
        I wrote dos-batch file that does all the firmware copy an extraction process for you.
        If you do a search for "Zip-File Extraction" in the advance search bar you should find
        the U-zip file to download. The use of the file assumes you know how to use a computer and sd card slot.
        The thread text shown is a copy of the batch file incase you are concerned about an PC virus. Simply copy and paste the entire thread text to a file and name it <anyname>.bat
        • copier tech
          • 8210
          • Riyadh hossain
            Re: firmware issue
            yea,,, problem solved.by downloading a software I can use larger stick
