MPC 6501 - Finisher not detected after firmware update
  • pajonk
    Guest replied
    Re: MPC 6501 - Finisher not detected after firmware update
    Originally posted by rpr383
    6501 never came with SOP,and on 6501 once you load the wrong firm on the fin cont you cant just reload the correct firm. The mach dosent know there is a finisher. so you have to replace. Ask me how I know!
    Hi
    just have above issue with finisher. Can I ask you to tell me how to sort this problem?
    order new pcb or can I swap from scrap fin?
  • rpr383
    replied
    Originally posted by Debs1964
    OK, I'll play along...how do you know
    Yes that was this guy, I failed on this once.
    replied
    Ask me how I know!
    Sounds to me like the voice of been there done that.
  • Debs1964
    replied
    ...Ask me how I know!
  • rpr383
    replied
  • Debs1964
    replied
    Where the problem can occur on machine firmware is on models that have a "Smart Operation Panel" option. SOP firmware can accidentally be loaded on a NOP, Normal Operation Panel, and the other way around.
    But that can be corrected by loading the correct firmware, it doesn't necessitate a board change.
    i haven't seen a SOP yet, but we did have a machine in the field that, somehow, had the SOP firmware installed, you get a warning message that you are not updating with like for like, but it will allow it to be done
  • rpr383
    replied
    Been there done that! need new PCB! Hope this helps. rfg052074.pdf
  • mikadonovan
    replied
    Thats good to know, but how was it possible for this poster to install the wrong finisher fw!?
    Easy.
    1. Load incorrect firmware onto card
    2. Update finisher firmware even though the P/N on the display is completely different than the one you are getting ready to load onto the eprom
    3. Curse profusely because you just smoked a board
    replied
    replied
    Is it really easy to load the wrong firmware? So is it possible to load 3002 engine fw on a 3003? Easy mistake to make if one is in a hurry!
    Main machine firmware is usually not a problem. The update process will only recognize firmware that is applicable to its model line. Where the problem can occur on machine firmware is on models that have a "Smart Operation Panel" option. SOP firmware can accidentally be loaded on a NOP, Normal Operation Panel, and the other way around.
    replied
  • Ramón
    replied
    I once had this problem with AF 3260C where an oversight joined the firmware update package from the machine an SR that was not installed. The SR firmware is placed wrong and the machine detected it immediately. I turned off the machine place that had SR without problems until today and go and 7 years of that problem. What I wont is a possibility that it worked, but as we all know technology has changed a lot since then, but I do not lose anything for trying.
    replied
    What result can give you is to connect the MP C 6501 to SR 5000 to be detected and will install the firmware. Once done reinstall the SR 4030 I do not think you need to change any motherboard.
    I doubt if this will work. If I remember correctly, the firmware for peripheral devices, such as a finisher, are loaded to an EEPROM on the PCB of the peripheral device. Once the wrong firmware has been loaded, you have to replace the peripheral's PCB unless it has a removable EEPROM, in which case you can replace the EEPROM. If you have another peripheral device of the same model with the proper firmware and you have the proper equipment, you can copy the EEPROM.
  • Ramón
    replied
  • Zerocool
    Guest replied
    Thanks ss12 for the quick reply and everyone else. Looks like i loaded SR5000 firmware on a SR4030. I will definitely not make the same mistake again
