Re: MPC 6501 - Finisher not detected after firmware update
Hi
just have above issue with finisher. Can I ask you to tell me how to sort this problem?
order new pcb or can I swap from scrap fin?
Guest replied -
6501 never came with SOP,and on 6501 once you load the wrong firm on the fin cont you cant just reload the correct firm. The mach dosent know there is a finisher. so you have to replace. Ask me how I know!Leave a comment:
i haven't seen a SOP yet, but we did have a machine in the field that, somehow, had the SOP firmware installed, you get a warning message that you are not updating with like for like, but it will allow it to be doneLeave a comment:
Been there done that! need new PCB! Hope this helps. rfg052074.pdfLeave a comment:
1. Load incorrect firmware onto card
2. Update finisher firmware even though the P/N on the display is completely different than the one you are getting ready to load onto the eprom
3. Curse profusely because you just smoked a boardLeave a comment:
Thats good to know, but how was it possible for this poster to install the wrong finisher fw!?Leave a comment:
Main machine firmware is usually not a problem. The update process will only recognize firmware that is applicable to its model line. Where the problem can occur on machine firmware is on models that have a "Smart Operation Panel" option. SOP firmware can accidentally be loaded on a NOP, Normal Operation Panel, and the other way around.Leave a comment:
Is it really easy to load the wrong firmware? So is it possible to load 3002 engine fw on a 3003? Easy mistake to make if one is in a hurry!Leave a comment:
I once had this problem with AF 3260C where an oversight joined the firmware update package from the machine an SR that was not installed. The SR firmware is placed wrong and the machine detected it immediately. I turned off the machine place that had SR without problems until today and go and 7 years of that problem. What I wont is a possibility that it worked, but as we all know technology has changed a lot since then, but I do not lose anything for trying.Leave a comment:
What result can give you is to connect the MP C 6501 to SR 5000 to be detected and will install the firmware. Once done reinstall the SR 4030 I do not think you need to change any motherboard.Leave a comment:
Guest repliedRe: MPC 6501 - Finisher not detected after firmware update
Thanks ss12 for the quick reply and everyone else. Looks like i loaded SR5000 firmware on a SR4030. I will definitely not make the same mistake againLeave a comment:
