Hello
I have a MPC 3000 that makes me crazy.......The machine has an image Problem , a kind of "white shadow" on every print/copy...on EVERY COLOR, and exact at the same position, at the middle of the sheet....i cleaned up everything, even the Polygon motor, i changed PCU UNITS, EVERY COLOR....TRANSFER BELT/CLEANING.....TRANSFER ROLLER....PRESSURE ROLLER....FUSER GEARS, recently i removed the LASER SHUTTER , still exact the same problem!!!!, im going mad.....see attached image (i used CYAn cause you can see the problem)
Any ideas?? THX
Any ideas?? THX
