Ricoh MP6000 Jamming
  • kannuki2
    • Feb 2012
    • 398
    #16
    Re: Ricoh MP6000 Jamming
    Originally posted by techsass
    I'm with Debs1964 slimslob & TonerMunkeh. That mylar usually goes out at around 2 million clicks.
    I have 2 machines which are over 2.8 mil clicks and the mylars are still good. Maybe my luck.
    • apump
      • Mar 2009
      • 160
      #17
      I have a MP7001 with 5.4 mil on it and never had the registration out or the mylars replaced. So it is possible. they ran 8.5x11, 20lb all the time.
      it was replaced a week ago with mp7502. hopefuly will be just as good
      • rbazan
        • Dec 2013
        • 70
        #18
        This may be a little late but, I had a similar problem on the same make and model. I found that a black mylar sheet that is right behind that registration door that keeps popping open was worn thru by the paper. I had to remove that section from the machine. It wasn't as hard as it looked. To repair it; I used transparent tape to cover the worn area (where the paper was catching)- hasn't jammed since.
        • trc
          • Jan 2007
          • 95
          #19
          • MIKON
            • Jul 2015
            • 188
            #20
            Are you getting jam code 012?Try another feed unit once they get contaminated with developer they are junk...
