Hello, Have a few very old Ricoh,Savin,Lanier copiers that used the 4MB cmia card to update the firmware, the new pc's don't have the mcia port so I need to get a cheap mcia to usb adapter looked on the internet found some but am not sure which one is the one that I need. Any help would be grateful on a model number who makes 's it any info. thanks
Ricoh Firmware using a PC MCIA card
Re: Ricoh Firmware using a PC MCIA card
What ever you get, make sure that it is PCMCIA I not II. Ricoh used to have an adapter board available for older desktops and towers. Your best bet is to get an old laptop with a functioning PCMCIA I slot on 2. I think the trial version of the software is still available. If you use the trial version, backup the registry before installing the software. When it tells you that the trial period is over, uninstall the software, restore the registry and reinstall the software. Installation places a date stamp in the registry that remains after uninstall. Hope you have or can find the 4MB cards.Comment
Thank you for the reply, I was thinking of just coping the bin fill to the 4MB card then installing it in its slot to rewrite the firmwareComment
Ricoh site for software: MCERICOH Home
You might also try Memory Card Explorer by Elan: Memory Card Explorer - Elan Digital Systems Ltd. Software Informer.. It shows a later version number so might run on Windows 7, again if you have a compatible PCMCIA card slot.Comment
The main thing is that you need to use Memory Card Explorer to write the .bin file to the memory card. I don't know if it will run on Windows 7 as I have only used it on XP. If you have a laptop with a PCMCIA I slots or a desktop/tower with a PCI PCMCIA card board, you could try running it in XP compatible mode.
You might also try Memory Card Explorer by Elan: Memory Card Explorer - Elan Digital Systems Ltd. Software Informer.. It shows a later version number so might run on Windows 7, again if you have a compatible PCMCIA card slot.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
Damn, old technology, upgrade that box & move on!Let us eat, drink, and be merry, because tomorrow we may die!
