Printing Multiple Copies alternates between horizontal and vertical
  • steveb0000
    I have a Ricoh Pro 907EX. Whenever someone prints multiple copies, it alternates printing horizontally and vertically. So one set horizontal, the next set vertical, etc. Is there any way to turn this off? I have people complaining about it. I looked at the copier settings and couldn't find anything.
    Thanks for any insight
  • Coptech
    worker drone
    • 460
    Re: Printing Multiple Copies alternates between horizontal and vertical
    turn off the rotate sort button? does it have a finisher?
    • CRISTIAN MULLER
      • Feb 2013
      • 145
      Originally posted by steveb0000
      Are you using Fiery?if not, what driver did you used?PCL, PS?what kind of finisher are you using?that's option in pcl universal driver that make group turned,if you are using other driver search for this option at finishing settings.
      • teebee1234
        • 1670
        As stated, there are a lot of variables to consider. I found this attachment that may (or not) be if use.
        • steveb0000
          Thanks for the help. There are two finishers it looks like. One for the upper tray which does the alternating horizontal and vertical with the second tray doing shifting of the papers. I gave them the options and they're fine with using the second tray instead of the upper tray. I just had no idea where to look for this.
