sc 544-002 mpc4503
  • Kengithinji
    • Jun 2016
    • 4
    #16
    Re: sc 544-002 mpc4503
    what problems are you having that makes you think you need firmware.
    please start another thread as this one is 6 years DEAD.
    I'm experiencing SC 544-02 that won't reset that's why
      what have you done to try and correct the problem?
      what parts have been replaced?
      did you clean any sensors?
      firmware is NOT a fix all.
      • FrohnB
        • Jul 2017
        • 1919
        #18
        If the fusing sleeve is bad, replace it. Then put a reset fuse in the available connector in fusing unit, and go into Service mode and Execute SP 5-810-002 "Hard High Temp. Reset".
        You can also just use a "New fusing Unit" that comes with a reset fuse already installed, and execute the above SP.
        Could be Fusing central NC thermistor (thermopile), BCU, or AC Power Supply also, if the above doesn't work.
        Omertà
          what WHAT? you mean as a copier tech I have to do some WORK?
          People think that FIRMWARE is a "Fix All"
          IT'S NOT!
          • Kengithinji
            • Jun 2016
            • 4
            #20
            IT'S NOT!
            The machine was working just fine except for black images of previous prints appearing on the current paper because of stuck toner on sleeve. Removed the fuser to clean sleeve then returned the fuser and immediately the error appeared
              go back over your work. clearly your "cleaning" screwed something up.
              • FrohnB
                • Jul 2017
                • 1919
                #22
                You might have damaged the sleeve when you "cleaned it". Have never heard of anyone "cleaning a sleeve" before. How did you clean it???
                Usually once it starts "ghosting" or tracking the image down the page like that, then it's time to REPLACE the fusing sleeve.
                Just replace the sleeve or fusing unit and execute the SP mode I mentioned. It's the ONLY way!
                Omertà
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  #23
                  By cleaning the sleeve you must of damaged the heating element you will need to replace oem sleeve unit in box will be a reset fuse this must be fitted in fuser to reset machine will not work without fuse
                  Regards Mark
                  • mikadonovan
                    • May 2008
                    • 2931
                    #24
                    Originally posted by en.
                    hi all
                    i made this steps:
                    1- upload nvram data from another device and down lode in the device who hade the sc
                    sc are gone but now the machine give me sc 995 -2
                    i put the sam serial number by sp 5801 in nvram and bcu
                    but it give sc 995-3???
                    THAT was a big mistake, and certainly not the way to clear a fusing code. The more I think about it, there is a strong possibility you just bricked the controller.
                    NEVER ASSUME ANYTHING
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      #25
                      Hi mika you just replied to the thread from 6 years ago that's what happens when users don't start new threads stay safe mate
                      Regards Mark
                      • kplow1986
                        • Nov 2013
                        • 41
                        #26
                        what about the fuse? it has been mentioned time n time again on this thread.
                        or did you buy some cheap ass china sleeve?
                        I can reset the code without using fuse... My practice is backup all nvram on each machine which is good condition, and restore back the nvram when replace fusing parts
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          #27
                          Regards Mark
                          • fshead
                            • 2376
                            #28
                            I did the same nvram backups when i was placing a bunch of mpc3502 in the field.
                            kept copies on my laptop as i had one machine that would not reset,would no blow the pico fuse either.
                            I do not do it on the 03 series as the fuser sleeve is more solid and reliable than the 02s
                            • Imprestik
                              • Aug 2012
                              • 297
                              #29
                              Wow this thread escalated quickly LOL.....
                              I should have updated it years ago but what I eventually found out is you don't even need to use SP5810-002 when you have this code.
                              Before switching off the device, go to SP3701 (i think it is) and set the fusing unit, belt and pressure roller to 1 to tell the device you are replacing it with a new fuser.
                              Switch it off and back on and off you go, the device will do process control, reset all fusing codes and fusing PM counters and work like a charm.
                              In saying this the fuser was also replaced
                              Never had a problem since
                              • copier tech
                                • 8164
                                #30
                                Exactly, basically follow what is says in the service manual.
