Aficio 2851 SC 144-01
  • wester
    • Aug 2009
    • 113
    We got this unit in the other day,had an SC 144-01 come up when we fire it up. I am able to print out SMC . Has anyone had any experience with this code. I checke the connectors from SBU through IPU to BCU no visible problems. Next step would be to find compatable machine and swap some boards. Any help out there?
    • 37490
    Re: Aficio 2851 SC 144-01
    Check connections between SBU, BCU and IPU. Check that you are not getting a low voltage coming out of the PSU. If PSU output(s) are low, check AC line voltage.
    Replace IPU
    Replace BCU
    Replace SBU
    • wester
      • Aug 2009
      • 113
      Replace IPU
      Replace BCU
      Replace SBU
      this morning I went to the next town over (50 miles) and swapped boards out. Turned out to be the IPU. Replacement from Hytec is on the way.
