sc402-52 in pro 5100
  • en.
    • Jul 2014
    • 124
    hi all
    i have pro 5100 it give me sc 402-52
    i checked and cleaned pcu and i tried to add toner manully in develloper unit it work and give sc 401
    can i reset sc without replace the developer??
    regards
    • 37487
    Re: sc402-52 in pro 5100
    SC 402-52 is Development gamma calculation error: Insufficient data (C). Try cleaning the ID sensor and then run manual process control. Since you have tried multiple forced toner, you have probably over toned the Cyan development unit, i.e. the SC 401 Development Gamma Low Error (C). If I remember correctly, development gamma is inversely proportional to toner concentration. If that is the case, replacing the developer is the only recovery. replace the developer, not the development unit unless the PM counter for the unit is near 100%.
    • en.
      • Jul 2014
      • 124
      thank you sir for your answer
      i now what you mean but i asked if i can reset sc by sp mode or any way without replace developer
      any one can help me?
      best regards
      • rosspt
        • Mar 2012
        • 92
        best regards
        No. Try cleaning ID Sensors and run Process Control. Reboot copier. If SC code returns you will have to replace the developer as Slimslob suggested.
        • Debs1964
          • Oct 2010
          • 1693
          ...If that is the case, replacing the developer is the only recovery. replace the developer
          You asked a question, you got an answer, probably not the answer you wanted, but there it is! If you want to clear the code without spending money I suggest you reset the NVRAM, but please don't come asking how to fix it when you f**k up the machine.
          I am probably feeling particularly impatient and grumpy today, but sorry, don't bother asking a question if you don't want to take the advice given
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Well debs that sounds alot like my last response to aaB1................ They ask for help, receive help and then ask for a different answer.....................
            Mystic Crystal Revelations
            • en.
              • Jul 2014
              • 124
              i checked id sensor and clean it but after i do process control it give me sc one by one like this :
              1- sc 374 then it give me sc 285 then
                • 37487
                If you are an end user, hire a trained and qualified tech. If you think you are a tech, get proper training and documentation. Any model name that starts with Pro is a production machine. It is designed for high usage and proper regular servicing by an experienced tech with the correct documentation on hand when he/she works on the machine.
