MP C4501 ERROR SC 120
  • fritzyas
    • Jul 2011
    • 73
    Hello friends I just want to ask help, we are facing a problem with MPC4501, when printing and scanning there is no problem but when copying SC 120 will pop out. we change SIO and stabilizer boards but still the same. All firmwares are up to date. Thank you for your help in advance.
    • 37532
    Re: MP C4501 ERROR SC 120
    SC120 is a scanner home position sensor error.
    • barratec
      • Jun 2008
      • 162
      Hi! Check the tension of the optical motor belts!
      • gestetner tech
        • Nov 2009
        • 45
        Check the drive motor for scanner.
        • fritzyas
          • Jul 2011
          • 73
          Thank you for the replies, we already replaced the SIO, STABILIZER, SBU, HOME POSITion sensors, bicu,scanner motors but still the same. Cleaned the mirrors but no improvements. When you copy using auto color and full color it will copy once then if you copy the next original it will show 120. When you copy using black and white it will immediately show 120.
          • ronald2020
            • May 2009
            • 31
            Hi Fritzyas
            Just out of curiosity did you ever solve this fault and if so what was the solution? have one doing same thing.
            • sharpmind
              • Sep 2009
              • 478
              Try to lubricate the railings of the scanner unit...
              • bob marley
                • Jan 2012
                • 1339
                think u need to check harness between scanner motor and SIO board
                Live for yourself and you will live in vain. Live for others, and you will live again
                • imaginemoko
                  unTrusted Tech
                  • Jan 2008
                  • 289
                  have you try sir to test a working ITB unit? a broken ground terminal of yellow bias roller may cause some noise interference.
                  fix the customer first then fix the machine... its simple and makes life more easy.
