Ricoh MPC 4500 Does not load the black toner
  • tibbs
    • Aug 2008
    • 225
    Hello I try putting toner in a ricoh mpc 4500 black but it does not accept it. Can anyone tell me why.
  • anothertech
    • 1771
    Re: Ricoh MPC 4500 Does not load the black toner
    Yeah, it needs a toner pump.
      • 37495
      Change SP 3045 [Toner End Detection Set] from 0 to 1. If the machine then functions correctly and maintains correct toner level, either the RFID chip on the cartridge is defective or the RFID board in the back of the machine is defective and the machine cannot read/write the toner level to the RFID chip.
      • Debs1964
        • Oct 2010
        • 1693
        If it doesn't attempt to load toner, then a cover is not fully closed, usually lower right one. If it does try to load, then it's probably the pump
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Had this issue last week with yellow - no toner - new pump - OK (for 3 days)
          No yellow toner - developer-clutch (yellow) gone - new clutch -OK
          Greetings...
          • Iowatech
            Not a service manager
            • 3930
            Because the chemical composition of the toner is wrong and it would damage the machine if it was used.
            Or something else.
            We can't help you efficiently unless you give us enough information. Try harder, please.
