LD145 open cover but none shown
  • verderacer
    • May 2008
    • 158
    Howdy all,
    Have a LD145 (B183) that says it has an open cover but the display does not show anything. All covers when opened and closed show properly on the display.
    Have disconnected all the accessories that I can but still gives the open cover. Double checked each door switch and all test fine.
    Anybody have any ideas on what might be the issue?
    Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
    MCSE/CCNE/ENS and other crap...
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Originally posted by verderacer
    Howdy all,
    change the door switchs above the fuser on right side.
    sigpicWe can all Win, but at the end we all loose. Save the greyhound
    • FRIDGEMAGNET
      • Aug 2007
      • 377
      I have not had this myself but if the door switches check out OK then I have heard that another cause can be the laser diode PCB.
      The door switch circuit goes through the LD unit and if this goes open then you can get the door open display.
      • verderacer
        • May 2008
        • 158
        It was the middle switch. It appears that the arm was bent in further than the others and when straightened along with the actuator arm so all the 3 switches get fully engaged.
        It's still a little funky but works consistently now.
        Thanks all !
        • nmfaxman
          • 1702
          Check for blown fuses in the Power Supply.
          Very common on Ricoh products.
          I believe FU1 will give a door open indicator because it is the main 24V power that routes through door switches.
          • Jomama46
            • 2900
            wake-up there, Faxman.
            sigpic
            A+; Network +; PDI+
            • verderacer
              • May 2008
              • 158
              Opps,
              But good for future knowledge !
