Ricoh pro c900 without SD Cards
  • ahmed9591
    • Nov 2014
    • 16
    Hi all,
    I recently bought a Ricoh pro c900 that came without the SD cards so the fiery doesn't show up on the screen and of course I can't use it. Please advice me what to do. is there a website that has this software that I can just normally copy it on a normal SD card and insert it in the machine or do I have to order the SD cards and where can I get them.
    Thanks in advance
    • 37068
    Re: Ricoh pro c900 without SD Cards
    The fiery controller is a separate computer mounted on the back of the Pro C900. It does not require an SD card as it is not actually operated by the main GW controller. Make sure that the fiery controller is installed, connected and turned on.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      On the c900 the standard Fiery is mounted inside the rear section of the c900. It is a complete fiery and does connect to the c900 via a cat 6 cable, but it is inside the rear section cover of the c900.
      Mystic Crystal Revelations
      • ahmed9591
        • Nov 2014
        • 16
        thank you both for your reply.
        unfortunately it is still not working. I made sure that all the cables are connected and even replaced the back part as a whole with another yet the fiery didn't show up on the touch panel.
        if you still have any piece of advice I can try I would be grateful.
        • tjvincent
          • 280
          I would try hooking up a monitor, mouse & keyboard to the Fiery and see if it tells you anything, i did have to reload System Software on 1 Fiery for this issue.
          • ahmed9591
            • Nov 2014
            • 16
            are you sure because some one who has the same machine sent me the below pictures and told me that the fiery has to be operated by the SD Card (shown in pictures). The SD Card slot is also in the picture
              • 37068
              http://i.imgur.com/8XhrInh.jpg
              There are two SD card slots on the Pro C900/C900S. Slot 2 is used for firmware updates and for the Java VM card. Slot 1 is used for MFP options: PostScript, Data Overwrite Security Unit and File Format Converter.
              The SD card you attached a picture of is a CE tool card and is used to load the customer paper types after it has been prepared.
              If the fiery menu is not showing on the screen, either the fiery server is not connected correctly, is not being powered up or has crashed. Since the service manual cautions numerous times that the fiery must be shut down before turning off the Pro C900, if the system had not been shutdown properly, the fiery could be crashed.
              • ahmed9591
                • Nov 2014
                • 16
                well first of all thank you for your reply. what you said is kind of shocking to me because I've been searching a lot for that SD Card and couldn't find now I understand why.
                you have told me before how to connect the fiery so let's assume that I connected it properly then how can I make sure it is turned on. If that didn't work I will be sure that the fiery crashed so in that case how can I fix it.
                thanks again in advance
                • anothertech
                  • 1757
                  Take the advice that tjvincent gave you and hookup a monitor, keyboard, mouse. That Fiery is just a windows XP computer. Make sure the fiery tower is plugged in and the switch on the back is turned on. Then turn on the C900 copier, the fiery should boot and you can watch the progress on the monitor.
                    • 37068
                    You need a service manual. You might also want to have the trouble shooting guide. I believe that there is a rocker switch above the power cord connector on the Fiery server. It should be on. There is a small window on the Fiery cover top corner toward the LCIT. There is a two digit display in back of the window. If t he Fiery is on, the display should also be on.
                    • ahmed9591
                      • Nov 2014
                      • 16
                      Thank you again anothertech & slimslob your information was very helpful.
                      but i need to ask what if the system is crashed, what could i do? do i install normal version of windows xp or is there a like a system package to operate the fiery and if there is where can i download it?
                      also i would appreciate it if somebody shared the service or troubleshoot manual.
                      thank you
                      • Tonerbomb
                        • Feb 2005
                        • 2589
                        Slimslob is right about the media card pictured. Your pic also shows the 900 system slots NOT the Fiery controller. The 2 digit display slim mentioned will display hexadecimal numbers while the Fiery boots, if it's successful it should show 00. You need a Fiery manual to figure out the codes if it stalls.........
                        • ahmed9591
                          • Nov 2014
                          • 16
                          So I connected a monitor, keyboard and a mouse and figured out that the fiery is working well & boots windows XP and the workstation or whatever it is called powers up but still the machine fails to connect to the fiery. when I press connect it says that it is unable to connect. I am sure that all the cables are working and connected properly. please advice me what to do or please if possible tell me where I can find the troubleshooting manual.
                          thanks a lot
