ricoh machine Mp4000 speed ,how upto MP5000
  • fuwei2422
    • Nov 2014
    • 49
    ricoh machine Mp4000 speed ,how upto MP5000, cotrol、bicu diffentsame i think fireware 。I want to have fireware ,anyone to give me to my email:fuwei2422@hotmail.com
    thankS
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: ricoh machine Mp4000 speed ,how upto MP5000
    Originally posted by fuwei2422
    ...fireware 。I want to have fireware
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      2nd post and want,want,want............ how about helping others out first????????????
      Mystic Crystal Revelations
      • Debs1964
        • Oct 2010
        • 1687
        If you meant firmware, that is also the same for the 2 models, tough luck!
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • Lagonda
          • Aug 2008
          • 1649
          Sorry to tell you but the firmware is the same for both models, its the controller board that's different.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3945
            Here we are, yet again, with another wannabe feebly attempting to speed up a machine.
            Not an accepted practice, and you invite a flock of angry birds by doing so.
            • Gift
              • Mar 2011
              • 2446
              this day kinda sucked - until now LOOOL
              • SargeNZ
                • May 2012
                • 263
                Guys I just got a Prius, how do I make it the same as a Tesla Roadster?
                • nmfaxman
                  • 1702
                  I have an old analog copier. I want it to print, scan and copy in color.
                  Where can I get the magic wand?
                  Answer: It sits under the tree that grows money.
                  • anothertech
                    • 1756
                    I have good news for you Sir, put in Frimwar of the Tesla and a new Roadster badge and you're in business! Oh, and bigger batteries.
                    • Debs1964
                      • Oct 2010
                      • 1687
                      I once had a customer, over several visits, insist that I make the copier work outside of its specifications, eventually I lost my patience and invited them to search my tool case for the magic wand, and if they found it, then I would "fix" their machine. I do believe that was the last visit I ever made to that particular customer
                      • fuwei2422
                        • Nov 2014
                        • 49
                        I knowe 4000 and 5000 the control board,BICU board diffrent ,the fireware is same , I think must have a tool can reboot the machine and write to machine ,but i donot knowe
                        ,now i want to fix the board EPROM file to anothe
                          • 36870
                          Whether the machine is a 4000 or a 5000 is determined by a number of things. Firmware (not fireware which is what fireman wears for protection), EEPROM and NVRAM are the same on both other data stored in the NVRAM. NVRAM data is specific to the machine. It contains counters, machines settings, encrypted Administrator names and passwords, serial number data and regional data. NVRAM data can be copied to a SD card for the purpose of saving on a PC naming to identify each as to the serial number of the machine it belongs on in case you have a NVRAM fail you will have all the machine settings needed to reload on a new NVRAM and have the machine running properly. Trying to copy it back onto a different machine can open a whole new can of worms and could result in hours or days of work in order to get that machine back to functional.
                          • Tonerbomb
                            • Feb 2005
                            • 2589
                            Copying nv ram from one Ricoh to another from the back up file can't be done even if you rename the file to the new serial number of a different machine. There are differences in the meta data of the file...........been there tried that, doesn't work....................................
