White banding (horizontal) on Ricoh MPC3003
  • divanda
    • Jul 2025
    [CQ] White banding (horizontal) on Ricoh MPC3003
    I have a MPC3003 with white horizontal banding, only in black. First visit : replaced dev box ==> after 2 weeks, same problem, then i replaced PCDU. 1 month later : same problem.... Any ideas?
    Thanks in advance
    Regards
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: White banding (horizontal) on Ricoh MPC3003
    These models are plagued by faulty ITB cleaning units and drum wax bars. We had cleaning units overfill and spill, and the wax bar in the drum units break apart and deposit into the devs.
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      have you checked Sir if you had toner stone on black toner cartrigde?
      fix the customer first then fix the machine... its simple and makes life more easy.
      • divanda
        Hi Ruben, thanks for your reply. Today i went to the customer, changed PCU, dev box, vacuum cleaned toner supply+ placed new toner bottle. Adjusted spring tension on drum wax bar. Thanks for the tip about itb cleaning.
        • divanda
          Hello, thanks for your reply. Placed new toner bottle today+new pcu and dev box.
