Ricoh 1075 Skewing, jittering, Buckeling
  • CaptnRed
    • Apr 2011
    • 57
    [Jamming] Ricoh 1075 Skewing, jittering, Buckeling
    Hi Folks, I've got this Ricoh 1075 shooting skew images.
    I rebuilt the drum, developer, and transfer unit. After completing the PM, I starting noticing a crunching noise. Images are skewed, when I open it up and run a long job, I can see jittering/buckeling from the registration hand off to transfer.
    I attached a video of the machine.
    Thanks,
    CaptnRed
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: Ricoh 1075 Skewing, jittering, Buckeling
    Did you disassemble the transfer belt unit and check everything is in it's correct place?
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • CaptnRed
      • Apr 2011
      • 57
      Been back several times, I back tracked everything I handled on the PM. re-seated the developer, re-seated the transfer belt, re-seated the drum unit. I'm not finding anything blatantly out of place.
      Point of note: I'm not 100% sure if the problem was there before I worked on it, Developer was shot to hell and had light to blank images after 5-10 copies were made, hence the PM. Machine has over 1.3 million clicks.
      • TOSKO
        • Feb 2013
        • 13
        Have you tried to see if this problem occurs from more than one tray. If it only happens from one particular tray check the vertical transfer guide to the right of the feed stations as sometimes the white idler rollers become dislodged and cause uneven feed tension when feeding and causing skew. Also check that paper in the tray has no folded corners. Hope this gives you some ideas if not already fixed. You can also check to see if the rego roller has even pressure on both front and rear
        • CaptnRed
          • Apr 2011
          • 57
          Thanks for reminding me. Yes, with fresh paper, we ran jobs out of all the other trays including the by-pass and the same problem occurs. Because of that, I focused in the processing area only.
          I haven't checked the gaping of the registration, I'm working on getting a transfer assy. and registration components. When I get back I'll check those white idler rollers as well.
            • 37365
            Almost every time I have had buckling with the B064/065 series it has been caused by the paper registration and relay section. You may want to pull that entire section out the right end of the machine. With 1.3M on it the Mylar guides might need to be replaced.
            • CaptnRed
              • Apr 2011
              • 57
              Yeah my inclination is its the registration assy. I'm looking at the PC and making a list of parts I need.
              Slimslob do you happen to have a cheat sheet for part numbers to order for the reg and relay sections?
                • 37365
                Just look it up in the parts catalog. Machine is old enough that it is be fore the dreaded 3D parts catalogs.
                • tcs04
                  FORMER Techie
                  • 1183
                  Agree with tosko / slimslob, at 1.3m may well need reg mylars. Does the machine have an LCT? These knock out the mylars.Also look for signs of dev spill around the reg gears, could be leaking dev unit seals and if so, check the 1 way bearings and possibly the feed and relay motors. If you hear a buzz or vibration as it jams could be a tight motor.
                  The image skew suggests a mechanical blockage in the feed system. Odd that it's on a long run, silly question, did you check and clean the reg and relay sensors, these would cause intermittent jams..... but not the skew (?) are all the transport rollers all seated correctly? Whats the jam history?
                  • allan
                    RTFM!!
                    • 5462
                    Swop out the whole entrance section to test.
                    Whatever
                    • tcs04
                      FORMER Techie
                      • 1183
                      Chances of having an AF1075 reg unit...... slim?
                      • mikadonovan
                        • May 2008
                        • 2931
                        At 1.3 mil, this is a good thing to check. Developer leaked into a feed unit causes serious misfeeding issues.
                        NEVER ASSUME ANYTHING
                        • Ben Around
                          • Apr 2012
                          • 151
                          Check the mylar guides before the registration roller. I had one fall off the other day causing skewing and jams. Also lots of noise from the paper hitting. I used two sided moulding tape from the auto parts store to reattach it.
                          • Oze
                            Ricoh Fanboy
                            • Jul 2008
                            • 1663
                            I hope this helps you out
                            • tcs04
                              FORMER Techie
                              • 1183
                              Be careful using cheat sheets!
                              They changed the parts on these machines as they progressed through 1065/ 75, into 2075 and then into the 6000 series. At one point the mylars changed, can't remember when, but be sure! Ive had guys order the wrong parts before and it's a bugger when you only find out with the reg unit on the bench.
