Ricoh 1075 Skewing, jittering, Buckeling
  • wester
    • Aug 2009
    • 113
    #16
    Re: Ricoh 1075 Skewing, jittering, Buckeling
    Originally posted by tcs04
    Be careful using cheat sheets!
    They changed the parts on these machines as they progressed through 1065/ 75, into 2075 and then into the 6000 series. At one point the mylars changed, can't remember when, but be sure! Ive had guys order the wrong parts before and it's a bugger when you only find out with the reg unit on the bench.
    Its been awhile but I remember having that issue with the #1 tray and it seems it was the upper relay clutch, the one just before the reg. I think it only shows up from the first tray because of the timing.
    • leo34staffs
      copierman
      • Aug 2007
      • 503
      #17
      Apart from duplex clutch everything is motor driven.
      Networking skills are advantageous but use of a 3m vacuum cleaner is essential
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        #18
        He asked for the cheat sheet.....I'm just passing it along
