MPC 305SPF with Jam issues in ADF
  • tonnerboy
    • May 2011
    • 212
    • 37533
    Re: MPC 305SPF with Jam issues in ADF
    If the jam code is 001, it might be a firmware problem. As the MP C305SPF comes out of Sleep Mode it sees the paper in the feeder, forgets that is why it came out of Sleep Mode and thinks Jam on power up.
    • tonnerboy
      • May 2011
      • 212
      It looks like that is the issue...
      What is the procedure? I dont see any firmware update to solve the problem
        • 37533
        Try just re-flashing with the latest firmware. Even if a module is already at the current level, redo it as well.
        • Zeldaman
          • Mar 2011
          • 946
          • tonnerboy
            • May 2011
            • 212
            Zeldaman, what do you mean about "sleep-timer on"?? The sleep time mode is always on... we just may adjust the range of 30 sec in to 60 min...
            The problem is when the customer put a document in the feeder when the device is in standby.
            • Zeldaman
              • Mar 2011
              • 946
              • tonnerboy
                • May 2011
                • 212
                Thank you so much. I will make sure that the latest FW are installed.
